Based on the picture in the link you provided there is a drain plug. I replaced that plug with one from www.fumotooildrainvalve.com. I can change radiator fluid when it's hot.
I replaced the radiator hoses when I put in the new radiator. If you look around the forum you'll see that it is strongly recommended that you replace all the spring clamps with the worm drive clamps, especially on the transmission cooler line hoses.
There is a thread that covers putting in the additional transmission cooler.
Does it fit fine with the stock fan shroud?
The two row didn't fit fine on my Titan. The fan came into contact with the radiator and broke the radiator, fan and shroud.
If you don't have overheating issues then I recommend you stick with the single row aluminum radiator.
Do they make an all aluminum single row?
