Okay I keep seeing where people are saying they have their truck tuned with the superchips cortex on the 93 tune with a 2* timing advance… My question is can you not do that with the 87 tune and if so where is it? Thanks in advance
Nope, can't do it with the 87 tune. Only the 93 allows the 2* advance.
If you have someone that is close to you that has Uprev, they should be able to do a 2* advance while you're in the 87 tune. However, I think that if you change the tune and go back, you'll lose it. Not sure about that.
That would be cool if it would work but I always retune to stock every time I go in to the dealer for service just in case they try to reflash it so I'm sure i would lose it then...
The Superchips 87 tune will not accept a timing advance from any software. I tried several times, and each time it was blocked.
