Hey guys what's the biggest tire any of you are running on a 20" oem wheel at stock height. Or better yet with either a mini lift or an adjustable coilover i.e. radflo/icon/saws in the front. I have stock 18" set up. I have 17" OR wheels that I just sent out to get powder coated flat black with 315/70/17 that when I did a dry fit look to have rubbing at the pinch weld. I also have a set of MM 956 with 325/60/18 with no rubbing, unless I'm at or near full lock and hit a bump. I just purchased a set of stock 20" OEM and I'm looking to go a little narrower and a little taller than my 325/60/18. Here is what I'm looking at for tire size. Oh and I'm looking for an A/T tread design. I'd like the tire at 295-305 width and overall ht. of 33.5-34" if it will fit. I might either have to put on a 6" kit or possibly get some upper control arms. My current set up is an 07 4X4 SE with DR/Icon coilovers up front for a leveled look approx. 2 lift in the front and stock ht. in the rear with DR/Icon shocks.
295/60/20 Nitto's Terra Grappler A/T Should be around 34", but Nitto says 34.5"
305/55/20 33.2
Falcon Wildpeak 305/55/20 33.1"
Toyo Open Country A/T 305/55/20 33.2"
275/65/20 34.1"
BF Goodrich 305/55/20 33.4"
275/65/20 34.1"
Goodyear Duratrac 305/55/20 33.2"
285/60/20 33.5"
There are more like Cooper, Hankook and Kuhmo. Just to many to list.
305/55/20 33.2
275/65/20 34.1"
275/65/20 34.1"
285/60/20 33.5"
