Took the T in this morning because I thought I had a power steering leak and I needed to get my front brakes looked at and an oil change. Well it turns out I was totally wrong. I do have a power steering leak but it’s really small and they said just keep an eye on it. They also said my front brakes are fine and the squeaking is probably from the extreme cold here in Denver.
On the other hand the fluid I’ve been seeing is actually oil, not power steering fluid, because I need a new oil cooler which cost $654, plus my rear seals are both leaking bad which is another $860, plus new spark plugs which I figured but that cost $374, rear shocks leaking which I also figured $320.
What really pisses me off is the rear seals, because I had them replaced at about 70k miles and now 30k miles later they are leaking again. The shop manager said they switched to a different type of fluid and that should help but it’s a known problem in the Titan and unfortunately Nissan hasn’t really done anything about it.
Just top put a cherry on top of everything, the oil cooler is two separate parts and he has to order them from two different places because nobody has them in the Denver area so my truck is going to be in the shop until late next week.
How hard is it to change the plugs? I asked why those were so much and he said each plug is $16 plus he said it’s a lot of labor to pull the entire top off to switch them out.
