As noted, its never been changed & its got about 104K miles. I called a local shop & they will change but said they use Max Life transmission fluid & its compatible with the Nissan matic J. I'm a little leery since its running great & the last thing I want to do is screw it up. Any thoughts?
I've also never cleaned or changed the screen under the pan, this shop wont do it. Should I get it done?
