I have a 2004 Crew Cab with under 100k miles that has an electrical issue that my dealer cant diagnose and I need help.
Background:
6 weeks ago I was towing my boat uphill on the freeway (Tow mode was engaged) when I lost all power and coasted off the road. The VDC and Slip lights came on my dash. The engine ran fine, but was in some sort of limp mode and would not go over 1500ish RPM. I got it towed to a local mechanic who replaced the throttle pedal switch but that did not solve it. He recommended I take it to Nissan. It was towed to Nissan Dealer in California who has had it for 3 weeks and they have just given up. They believe it is a short somewhere in the wiring harness, they even replaced the ECU and got the same errors. It would $2-3k to replace the wiring harness so they recommended that I source out a good electrical shop.
Two questions:
First- Any idea what could be causing this? The codes that are being tripped are the following:
P2138
P2122
P1229
P0550
Every code that is being kicked back by the computer has been checked/replaced and is fine. When the harness is plugged into the ECU they get a ground signal instead of power then the codes appear.
Second- Can anyone recommend a shop in the Folsom/Sacramento area that can handle this type of issue?
Thank you so much, Im really backed into a corner here.
Background:
Two questions:
P2138
P2122
P1229
P0550
