Check behind your muffler and see if the connections broke and exhaust heat is spewing out of it you might have fried your wires above it
Well all the lights you said that are lit up are affected because that harness has all the wiring for the rearWhat do the connections go to that I am looking for?
Any updateThanks guys! Sorry it took a month to reply. Had to move across country for work. I haven’t been around my truck since I posted but I’ll definitely look at the harness tomorrow and give an update.
My 04 has the rotor issue that was it my 08.5 was flawless regret selling that long bed. Then had an 08 that was beat bought it used nothing but trouble traded it for a 2012 SL sadly had to replace the entire suspension up front and shocks in rear still doesn’t ride like it should but not bad enough I would get rid of it it has 107,000 on it now and Blackstone labs just analyzed the oil and said it’s better than perfect said I can go 7,000 miles before changing in futureSELL IT FAST. CUT BAIT. I had a ton of issues with my 05. Loving my 2014. Buy newer. Much improved
Yeah I’m still chasing the issue. Gonna replace the front abs sensors and replace Oxygen sensors today. And hopefully that fixes the codes. I’m trying to sell it. We’ll see what happens lolMy 04 has the rotor issue that was it my 08.5 was flawless regret selling that long bed. Then had an 08 that was beat bought it used nothing but trouble traded it for a 2012 SL sadly had to replace the entire suspension up front and shocks in rear still doesn’t ride like it should but not bad enough I would get rid of it it has 107,000 on it now and Blackstone labs just analyzed the oil and said it’s better than perfect said I can go 7,000 miles before changing in future
