yes ,it is a 4x4. i figured they'd be ok since 285's come on the stock 17" rims. just wanted to double check. thank you for your feedback.They should fit fine if you are a 4x4 (you sit a little higher up front) and will most likely fit the 2wd trucks. They are only roughly 33" tall and 11.6" wide, so basically a wider version of the tires found on the Pro4X trucks (275/70/18) and less than a 1/2" taller than your stock tires.
