I am trying to figure out my leak. it is a constant run of oil leaking out. The leak does not seem to be running from above near the head gasket. Oil is clear, no milkiness, no smoke. so I dont think i have a head gasket problem. The oil runs off of the oil filter component. Oil filter seems to be seated good and not coming from the filter fitting itself. I think it may be the actual unit that is connecting the oil filter to the engine. Has anyone come across this problem before? Or know how to fix it? Im going through 1-2 quarts a day. This is a big problem. started using 10w40 and slows a little, so i think it is very small leak. Any advice would be helpful. Thanks
