when i turn the key, nothing happens, at the starter relay there is no voltage to close the circuit. the only thing that happens is that the radio turns off. the battery shows no drop in voltage when key is turned, 12.9 volts. i have checked all fuses both visibly and with continuity test. i have tried the nats reset where you turn on/off 3 cycles while leaving it on for 5 seconds, i took off the neutral safety and everything seemed to be connected, however i didnt check for continuity because i could get easy access for the probes.
this truck always started, but then it sat for maybe 2 months...
oh, it has a new IPDM already and i checked each relay by putting 12 volts to it and all relays closed and showed continuity, i also swapped relays to try it as well.
i feel like this is an ignition/security type problem...any help?
