1 - 8 of 8 Posts
2005 Titan Bedliner, Bed-liner, or Bed liner issues w PIX
Thought these pictures might help others identify bedliner problems so that they can get Warranty service before it is too late and identfy it to Nissan Consumer Affairs 1-800-647-7261. Don't forgot to check for indentations under Nissan bed extender rubber feet.
Milky-white bedliner floor (TSB out there for this)
Bubbled (TSB out there for this)
Nissan bed extender damage
Discussion Starter #3 (Edited)
I forgot to mention these are pictures after it was repaired 4 months ago. All this happenend under the 3 year, 36000 mile warranty.
There are 3 TSB's for the bedliner issues: NTB05002(a), NTB05-044, and NTB05083.
I understand it is a truck, but Nissan found actual problems that were causing the bedliner to turn milky-white and bubble. My VIN # fell in line the TSB's. I am just glad Nissan is taking care of the problem.
Discussion Starter #4
Update - Nissan plans to provide rental, completely strip out the bedliner, replace with Rhino liner, re-install Ulti-track to Nissan specs. I will update once the repair is done.
I have the Rhino liner that Nissan installed for me. My bedliner was turning white too. They fixed it and it has been fine for about 9 months now. The only problem is they need to keep your truck for about 3-4 days. If you don't mind this, it is great. I would bring mine in if this was happening. The bubbling really concerned me because I was worried about rust underneath the bedliner.:Warp:
Hopefully will be picking up my titan tonight with new rhino-lining. Had a 12" split in the factory LE bedliner that went to the metal underneath. Dealer took pics to send to Nissan and they said nothing was wrong since it was not a bubble. I know the bedliner is made to take beatings and I have scratched it up quite a bit, but a split is a gateway to rust underneath. So the dealer and the regional rep agreed that it needed to be fixed and the only reliable fix is to strip it and rhino-line it. The stupid thing is that there are only certain places that authorized to do it?? I will have to clear up whether the warranty is from nissan still or by rhino lining, hopefully the lifetime rhino warranty.
Mine is a '05 CC LE.
Steve
stock liner suckssss its like sand paper glued on...i had the dealer throw in a line x for me. by far the best one ever.. ive heard problems with rhino but never line x. also they lined my tailgate too instead of cheap plastic cover...
It's too bad you got Rhino. It's going to turn more white than the factory liner. If you get LINE-X with Xtra, it resists fading, no loss of gloss, and is available in black or exact color matching.
Rhino (partially wet):
LINE-X Xtra in black(with lots of sun reflections):
1 - 8 of 8 Posts
