1 - 1 of 1 Posts
Hi I have a 2005 Nissan Titan I think it’s stuck in 4th gear and it’s not coming out of it. When I hit 40mph there is a humming noise from the front left side I have replace front dif/ t case transmission/wheel bearing cv axles drive shaft upper lower control arms replac the Steering wheel with all the controls I push the button then does not even go into fourth gear on the steering column so the whole column has been replaced. My question is is there a relay Or a fuse to check because I cannot find it. please if anyone help
1 - 1 of 1 Posts
