1 - 3 of 3 Posts
I purchased 2006 titan 2 years ago. A couple of days ago i had problem with the truck. While driving abbout 2 miles it just died out. It would sputter n rough ide. The gauges were flickeribg for a couple of seconds . Then suddenly i start it back up it ran fine so drove it back home 2miles but about 200 feet from home at a stop light it dies n wont start up again. I pull home n run the obdII on n it gave me codes for maf sensor n intakeair temp . I replaced the air flow sensor n it started up onetime runing fine. I drove the truck for about 6 to 8 miles n it ran fine .the next day i drove short trip maybe 100 ft. Came back everything working ok. This was about 11:30 am , at about 5:00 came out to warm up the truck again to go somewhere then it dies after idleing for 2 mins..now the truck wont run.ran obdII again n nothing new......i saw something about IPDM relay and a way to temp test the relay by swaping the fog light relay temporarly to test the ipdm relay. Nothing......im stuck any help would greatly apprecitated.....ed in guam........
I have had similar symptoms, and exact symptoms the same throughout the years (never plugged in a code reader). It has always been one of 2 things. Battery is going, or one of the terminal clamps is loose. I hope this is your issue, because the fix is easy. The terminal not being tight is a free, easy fix, but also, my Titan from brand new ate a battery like clockwork every year and a half until I set up a dual battery system. Look to the easy stuff first, and if possible, upgrade the 'coat hangar' factory terminal clamps to solid ones. Not expensive at all.
Hope it helps
Dying batteries do strange things to these trucks.
Mine is about 2yrs deep in battery #2, and the OEM lasted about 3.5yrs. We'll see if this one goes at 3.5. I'm watching for bizarro symptoms.
1 - 3 of 3 Posts
