First post, long time lurker. Just ordered some new tires for my 2006 CC Titan (285 70R17), figured its beyond time to replace the stock struts so might as well do it all at once. I was originally going to just order the Bilstein 5100s and put them on the middle setting to achieve a little front end lift and call it a day. After reading through some of the posts (of which there are many!), I am also considering ordering 08 moog 4x4 coil spring along with the 5100s and keeping the 5100s on the lowest setting achieving some lift with the longer/stiffer coil spring.
Is there any advantage to one over the other? I am not mechanically experienced or knowledgeable, I just want the best performing system that will give me a little front-end lift.
Thanks!
Thanks!
