1 - 2 of 2 Posts
Hi I have a 2006 crew cab LE. My rear passenger door is locked shut closed. I took the door panel off. I see one cable has been stuck underneath the window. SO the cable is split Broken in half. One cable for the lock is fine. The other cable with the yellow tag on it was over extended. My problem now is I cant open the door By pulling the cable. It's locked shut Outside door handle cable is broken off. How do I get the door open when it is locked shut with out the cables working? Thanks for the help in advance Peace!!
1 - 2 of 2 Posts
