Hi Folks, brand new here and trying to sort out an '06 Titan no start that has been brought to me by my wifes sisters husband, as a last ditch effort to save the truck. This post is EXTREMELY long, and I apologize for that - but I am trying to get all the information I have gathered as accurately as possible - in hopes that someone can help me sort this out!
A little back story - truck started having occasional no start issues last winter, generally would start the first time, then not the second, then start again, but not the time after that etc... Eventually it got to the point where the truck would not start at all, and then would not even roll over. In April of 2016 the truck was taken to a garage where they removed the computer, another "box" under the steering column (for some reason) and were not able to resolve anything. I have no idea of the skill level of this garage, but they didn't really seem to do much other than offer to buy new parts and try it - not at their cost of course. Truck was there for months, either due to inability to resolve the issue, or time, or... I really don't know. In late November my sister in law contacted me and asked what they should do, part it out, sell it as is, or just junk it. I told them if they were not in a rush they could drop it off at my place and I would fiddle with it when I had spare time. That's where we are now..
Truck arrived at my place just before Christmas, and I had been Googling the symptoms so took a preliminary attack at all the very basics... Started by putting back together all the things I could find that the garage had taken apart - including re-installing the computer, and "box" under the steering column (seems to just be a harness junction point, that I wonder if they had confused with the IPDM?). With all the components back in place, I turned the key hoping for some magic, and of course - got nothing. (wishful thinking). From here the very first thing I did was remove the battery connections and clean them - The positive post was horribly dirty - as well as the connection between the post clamp and the fuse block. This did gain me some good - the truck now cranked over, but would not fire.
Next I pulled a plug to check for spark - nothing. So, without spark I know it's not going to fire, but why don't I have spark?
Thinking possibly the Crank position sensor was blown (preventing the ECM from knowing when to fire) I checked resistance of the coil, and it was there - don't remember what it was, but it was there. I assume from this, the wire inside is not broken, hence it should be able to send a position signal to the ECM - but I could be wrong?
Obviously at this point I was starting to get somewhere, and now started checking things like the relays in the IPDM. At first I just swapped the ECM relay with the Fog light relay - to see if it would go. Still no-go.
Next of course I tried to read codes - and this is where I ran into some strange-ness... I couldn't seem to connect to the OBD-II system at all - it just "failed". I also noticed that the mileage was not showing up on the dash display. I was curious if this meant that perhaps the computer was fried - or maybe that the computer was not getting power, or ground. I searched the ECM harness pin out so that I could check this.
Today I went out into the shop to start poking around again. Checked the battery voltage (I've had a float charger on it) and it was good. Figured I'd pull the IPDM out again, pull the relays and check coil continuity, and verify that they were working. As I pulled the board out - I disconnected what I believe is the main power feed wires (black and red) - and decided to check them as well. Red wire to battery ground was good, but oddly, I also had 12V on the black wire. (?!) - Not sure if this is normal when the ignition is off??
While doing this I was cycling the ignition to verify when I had power where... and oddly enough, on one of the ignition cycles - I could see the mileage - WOAH - being hopeful, I cranked it over, but still no firing.
Anyway - I pulled the ECM relay and checked the coil - resistance was 151 ohms. I also made up some short leads and triggered the relay from a battery - clickity click - seems to be working fine. Also checked the relay contacts are connecting when the relay triggers - and they are. tested fine 10 out of 10 times.
Since I was able to get the mileage to show up, I decided to try to connect to the OBD-II again, and managed to this time!! At first I was just connecting using a cheap eBay Wifi adapter and the DashCommand app on my phone - but it was enough to tell me that it had actually connected (where previously it would not). It didn't manage to tell me much - but I did get some info;
___________________________
Engine Codes;
0 Stored Codes found
0 Pending Codes found
0 Permanent Codes found
Readiness Monitors;
4 complete
3 incomplete
Knowing that there must be more to the story than this, I broke out my Ross Tech VAG-COM. (for those who are not familiar, this is the kick *** read/write VW software, but also has generic OBD-II capability)
So, here is what I am able to gather from the truck...
_________________________________________
Wednesday,28,December,2016,13:42:58:25489
VCDS Release 16.8.4 (x64): Generic OBD2
Mode 9 : Calibration Identification
Type 02 - VIN : 1N6AA06F28N312409 (Address E8)
Type 04 - Calibration ID : 1ZR25B (Address E8)
Type 04 - Calibration ID : RX2485 (Address E8)
Type 06 - Calibration Verification Number : 0CB9D1C1 (Address E8)
Type 06 - Calibration Verification Number : 000059AF (Address E8)
Type 08 - In-use performance tracking :
OBD Monitoring Conditions Encountered count : 4379
Ignition cycle count : 15866
Conditions completion count / Specificied conditions encountered count
Catalyst monitor bank 1 : 7282 / 4372
Catalyst monitor bank 2 : 7270 / 4372
O2 Sensor monitor bank 1 : 7697 / 4376
O2 Sensor monitor bank 2 : 7733 / 4376
EGR-VVT monitor : 9549 / 4377
AIR monitor : 0 / 0
EVAP monitor : 511 / 1138
Mode 01 - PID 01 : Readiness -- Address 7E8
Number of DTCs stored: 0 -- MIL Status: MIL OFF
Misfire monitoring: Passed
Fuel System: Passed
Comprehensive Components: Passed
Catalyst monitoring: Failed or Incomplete
Heated catalyst monitoring: Not installed.
Evaporative system monitoring: Failed or Incomplete
Secondary air system monitoring: Not installed.
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring: Failed or Incomplete
Oxygen sensor heater monitoring: Passed
Exhaust Gas Recirculation: Not installed.
Mode 03: Emission related fault codes
Address 7E8: No fault code found.
Mode 10: Permanent Fault Codes
At this point I decided to see if there was something preventing the computer from firing, so an easy check would be voltage. Not sure what Nissan uses for a cut off voltage, but figured I'd check it. "Static" is just with the ignition on, "Cranking" is obviously while cranking... Voltage seemed to be getting a little low at this point, so I hooked my charger up to boost it a little (second readings)
Mode 1:Read Data
Static 1
42:Control module voltage 11.680 V
47:Absolute Throttle Position B 7 %
Cranking 1
42:Control module voltage 8.640 V
47:Absolute Throttle Position B 9 %
Static 2 - charger connected to boost voltage
(DVM at battery reads same as OBD voltage)
42:Control module voltage 12.560 V
Crankng 2 (after several Key Cycles to get milage to show again!)
(RPM was 138 during cranking)
42:Control module voltage 9.360 V
____________________________________________
So, I have a few unknowns at this point, that I am hoping someone can help me with...
1)What is the minimum ECM voltage Nissan requires to fire up the engine? Does a 3V drop seem excessive?
2)Can the emissions issues noted above in Bold/Italic/Underline cause the engine to not fire, and if so - where should I hunt down what is causing these errors?
3)what is the minimum cranking speed (is there?) for the engine to fire? - is 138RPM too slow for the ECM to fire the plugs?
4) SHOULD I REALLY HAVE 12V on the black wire feeding the IPDM, and where does this wire come from? (this was measured while NOT plugged into the IPDM, right at the plug on the harness, with reference to the battery)
5)Aside from the obvious problem here that I appear to still have an inconsistent ECM power up - where should I be looking for what is causing it to not fire?
Thanks a bunch for reading through all of that - I really hope something here is an obvious "Well there is your problem!" to someone!!
Bruce
Engine Codes;
Readiness Monitors;
4 complete
3 incomplete
AIR monitor : 0 / 0
Fuel System: Passed
Mode 1:Read Data
Static 1
Cranking 1
Bruce
