Hey guys, long time lurker, first time poster. I have a 2006 Titan 4x4 that will not crank. Last week it cranked in the driveway and then went dead. I tried to crank it back up and it would crank but would idle really bad and spit and sputter. When I would try to give it gas it would go dead. I finally got it crunk and it ran fine. Being kinda leery, I took it to the shop. It wouldn't crank there either, so they reset the computer. It ran great for a week and now has started back doing the same thing. The mechanic thinks it might have something to do with the keyless start and alarm I have installed. You can hear the fuel pump sucking when it tries to start. It won't crank at all now and I am at ends on what to do. Anyone ever had this problem? Spending a grand on it at the dealership right now would suck with a new baby less than a month away. Thanks in advance.
I'm not a big member on here, nor am I a technical expert, but I can offer yous some frugal advice. Go to a good body shop and tell them your problem, have them inspect it to find the problem, then from there figure out cheapest place to fix it.
I have no idea about your Titan but I was struck by your use of your term "crunk" since I've never before heard the word. After seaching with Google, I learned the meaning of the word "crunk" and it seems that may have inadvertently indentified the problem with your Titan.
Check out "Crunk": What does CRUNK mean? - CRUNK Definition - Meaning of CRUNK - InternetSlang.com
theres a relay recall and the relay has something to do with the truck starting. call a dealer and ask them if your vehicle falls under the recall
I just got the recall done, it was about the truck shutting off while driving, not starting, AFAIK.
does nothing happen? or does it try to start and nothing happens? could it be the starter?
