2006 titan wont start
684 Views 2 Replies 3 Participants Last post by  TitanBlue
about five times in the last 2 months i would turn the key on and all the dash lights would come on, turn the key to crank and nothing, not even a sound. after jostling the ignition a few times it would fire up with no drag or problem. went to autozone and battery was bad(under warranty so free swap out). thought this would fix problem, but next day did same thing. any suggestions on where to start? 140k mi by the way
1 - 3 of 3 Posts
I don't recall the details now, though i should, but read up on the ECU Relay (on the IPDM) Failure threads. They are sticky threads.
Also, are you sure your Alternator is charging fine? It should be, or a light should have come on.
1 - 3 of 3 Posts
