Hey there, I just purchased my 07 Titan a week ago and have been trying to replace the factory stereo system with something a little more modern. I've done successful stereo replacements multiple times in the past, but those cars did not have amps and instead relied on the built-in pre-amps in the HU.
So, I wired up the new stereo, using the metra harness which has 4 RCA cables coming out for the speakers. I plugged these RCA cables directly into the back of the stereo as it has RCA ports that it indicates should be used if using an amplifier. It also had regular stereo wires coming out, but I believe those would bypass the trucks amp? Anyways, this didn't work. I am getting sound out of the speaker, but it is so minute that I have to have my ears up to the speaker to hear it when put at full volume.. basically it is completely un-amplified. My factory stereo had no problems so I don't believe the amp is bad..
My question is, what am I missing here? Do i wire the speaker outputs straight to the amp and skip the harness? Is there another harness I can just splice into that has the lines going to the amp? I can't figure it out! Please help.
