2008 2wd Lift? Please See Pic For Help!
2417 10
Guys, I have decided to keep my 2wd for a year or so and I would like to get this exact same look but keep in mind my truck is 2wd!
I snagged this pic off of the forum, to the owner, you have a nice truck!
I think he is running 35's.
Thanks,
Cole
1 - 11 of 11 Posts
Yeah... Leveling kit with 33's would be my guess.... Same as mine.
Well the 2008 sits a bit more level from the factory than previous years, so I'm unsure of what size spacer you'd need. You can fit 33" without any spacer (stock tires are 33" diameter already.)
Now you have me worried, as I dont want it to be riding high in front. I plan on going with the 2.5" Mini lift and the 1.5" in rear.
Has anyone installed one on an 08 yet?
All I know personally is that my father's stock '08 sits nearly as level as my '04 with a level kit and 1" blocks in the rear. I'm not sure if they lowered the rear or raised the front, but it's definitely got less rake. Your best bet is to contact Greg directly, as he should know for certain.
Here's mine (back when it had 17"s and Nittos on it):
if you want that look it helps to not have running boards. Those drag the visual height of the car lower quite a bit.
1 - 11 of 11 Posts
