For just over $300, I believe, I got a set of powerslot rotors and EBC greenstuff pads on AutoAnything. Soooo much better than stock equipment. My stock 08 rotors had been turned twice and were warped again at 40k. The powerslots have a directional vane so they shed the heat more effeciently which helps resist warping. If you can spend the money I recommend it.The post is kinda old but I thought I'd ask if this was still available.
For just over $300, I believe, I got a set of powerslot rotors and EBC greenstuff pads on AutoAnything. Soooo much better than stock equipment. My stock 08 rotors had been turned twice and were warped again at 40k. The powerslots have a directional vane so they shed the heat more effeciently which helps resist warping. If you can spend the money I recommend it.[/QUOTE sounds like you wait last minute to brake like my wife. If you brake sooner and softer everything lasts longer. slotted is rough on pads, but doesn't matter. I put them on instead of buying stillen kit.
Not so much last minute as a function of how fast I typically drive, that plus I sometimes have to haul stuff around. I wasn't trying to crap on your thread I just figured with as old as it is you weren't still trying to sell them.sounds like you wait last minute to brake like my wife. If you brake sooner and softer everything lasts longer. slotted is rough on pads, but doesn't matter. I put them on instead of buying stillen kit.For just over $300, I believe, I got a set of powerslot rotors and EBC greenstuff pads on AutoAnything. Soooo much better than stock equipment. My stock 08 rotors had been turned twice and were warped again at 40k. The powerslots have a directional vane so they shed the heat more effeciently which helps resist warping. If you can spend the money I recommend it.
