Just wanted to post some pictures and info on my 2008 NISSAN Titan pickup that had what could have been a CATASTROPHIC failure of the emergency brake system (parking brake for some).
We had just left the house and gotten about 1.5 blocks from the house in a 20 mph speed zone, when it sounded like the rear end was going out or a drive shaft (u-joint failure). But the ABS and slip lights came on immediately, sending my thoughts to brake failure. I got in the bed of the truck and had my wife drive slowly home while I listened. It sounded loud on the passenger side. After removal of the caliper and rotor, this is what fell out. Contacted Nissan Consumer Affairs about the problem, and told them that I had researched this on several Nissan Forums, and found it numerous times. They set up a case, and had me take the truck to a local Nissan dealership (and pay almost $100 to have them look at it and report to Consumer Affairs). I got a call this morning and the case manager said Nissan was not going to do anything as the truck was out of warranty (DUH, if it was in warranty, would I be calling CONSUMER RELATIONS?). The bill to fix the problem is $2400.00. I called the dealer and told them I would be picking up the truck. This is a SAFETY issue. If this had happened at highway speed, I suspect that the axle would have sheared, I would have possibly lost a wheel and control of the vehicle. Nissan can kiss my *** and I will not spend another penny with them. I will also post this everywhere I can to let people know what NISSAN thinks of their customers and their SAFETY.
The system came apart (I believe due to shoe material decomposing), and took out the shoes, retaining pins, anchor block, tone ring, abs sensor, backing plate, adjuster and shoe hardware. Will also need new seal, bearing retainer, rotor/drum, etc. when the axle is pulled to fix this. Over $700.00 in parts alone.
