Sorry I can't help with that question but, the dealers system works great for under about $300....and you use the factory FOB. Just an idea. Good luck.gksmith said:Just got my truck and I need to add a remote starter. I just want to verify that the Valet 561T and 556U will work on the 2008 with the factory security system and keyfobs.
That's sort of correct. Yes, it's not a factory or Nissan system but is installed and warrateed by Nissan ( I believe they all use the same one). I had it put in the wifes 05 Quest and have been VERY happy with it. Sorry I wasn't clear.Arachnid said:I called my Nissan dealer and they said that there was no "dealer" system, but that they would install an aftermarket starter of my choosing.
Same for me. I checked when I was picking up the truck and they just gave me the name of the place they use for installations.Arachnid said:I called my Nissan dealer and they said that there was no "dealer" system, but that they would install an aftermarket starter of my choosing.
I can see if I can find out the name of it. My dealer installed it and uses the factory fob. You just hit the lock button twice to start it (it'll then run for 5 to 15 minutes depending on what you ask them to set it at). And hit the lock again to shut it off.Arachnid said:I bet that all the dealers have different policies. I'll check again next time I drive by. $300 isn't a bad price for one that works with the factory fob and has a warranty.
Any updates?HudsonValleyTitan said:I can see if I can find out the name of it. My dealer installed it and uses the factory fob. You just hit the lock button twice to start it (it'll then run for 5 to 15 minutes depending on what you ask them to set it at). And hit the lock again to shut it off.
amen... im liking this, once theres more info!gksmith said:Any updates?
