I've got 35 lbs in tires. it's an 4X4 SE CC LWB. Any ideas?
M more_air · Registered Joined Nov 17, 2007 · 5 Posts Discussion Starter · #1 · Nov 17, 2007 Only show this user I've got 35 lbs in tires. it's an 4X4 SE CC LWB. Any ideas?
BayStateSuks · Registered Joined Sep 13, 2007 · 446 Posts #2 · Nov 17, 2007 Only show this user Drive around for about 10 miles and see if it goes off. That is what I used to have to do in my '05. Once the tires are hot, the pressure should go up and the light should go off. Alternatively, put about 37 psi in each and see if that does it.
G gyrate · Registered Joined Jul 30, 2006 · 969 Posts #3 · Nov 18, 2007 Only show this user Mine's been on for a week now, again. Ignore it. I am almost to the point i'll pull the cluster and remove the light bulb. If you bring it to nissan they will waste 3-4 days of your life and sent you back home, only for it to come on again.
C crymeariver · Registered Joined Nov 15, 2007 · 64 Posts #4 · Nov 18, 2007 Only show this user hello everyone this is obly a test been havina a really hard time postina a message
