2008 Titan rear parking brake delaminated
1323 Views 3 Replies 4 Participants Last post by  Ransx77
This caused the Slip and ABS light to come on. I can DIY the brakes but how about the sensors?
i had the code 4211 i think it was and what fixed it was the brake booster sensor.
It depends on the damage caused by the parking break failure. Hopefully it is as simple as replacing the wheel speed sensor, but could be worse. If the tone ring that the speed sensor gets it's reading from is damaged, I believe you have to pull the axle from the rear end to fix it. I can't remember exactly, but do know that there is a thread on here that gives explains the process. Good luck.
Dude, this is the forum for the new 2nd generation Titan....take this to the old Titan section.
