1 - 2 of 2 Posts
i want to do a 20 inch wheel with the Nitto dune grappler tires, what is the largest set up I can get under a stock Pro 4 x 2010, I have no level kit etc, stock stance can you help Brett:confused:
Supporting Vendor
Tire & Wheel Specialists
Thank you for the post Brett. We would be happy to help.
I suggest running the Dune Grappler in size 305/55-20. This size is just over 33" in diameter and is 12" wide.
Wheel dimension wise, I suggest looking for a wheel that is 9" wide with an offset range from 0mm to 25mm. +18mm would be ideal.
-Matt
1 - 2 of 2 Posts
