I am having the dreaded "no start, just click" issue with my Armada. There are literally hundreds of posts about this. My vehicle will start with no problem 50 times, then suddenly I'll just get a single click. Then, after anywhere from 5-25 tries, it will sluggishly start and be fine again for 50 more starts. The simple fix I've seen over and over again is replacing the starter relay or the ignition relay or both. The problem is, I can't find a definitive diagram that tells me where the starter relay is and where the ignition relay is on a 2011 Armada. I keep coming across two different diagrams of the IPDM.
Here is a photo of my IPDM:
Here is the diagram that I've found that matches the photo of my IPDM:
So, in the photo, the ignition relay would be the one on the far right, under the yellow fuses. I've replaced that relay, but the problem remains.
What I can't figure out is that I keep coming across this diagram online when I search for 2011 Armada IPDM diagram:
This diagram suggests that there is a ignition relay AND a starter relay on the same IPDM board. But it does not match the layout of my IPDM board.
SO the question is, if the first diagram is correct, and I've managed to replace the ignition relay with no luck, where the hell is the starter relay on a 2011 Armada Platinum???
