I have a 2012 Titan SV. Bought it new. Came with a hitch for hauling. Can anyone tell me what the hitch class on this make/model is? Thanks!
Should be a class 4. It should be stamped on it. 1000/10000 lb
That doesn't mean you can pull that much with your truck...
^^^ What he said!
The owner's manual should have the tow capacity info. Even on my '07 the hitch had a printed rating that was higher than what the owner's manual said. Keep in mind that you can't exceed the cargo capacity also. If your cargo capacity is 1400 lbs and you have a tongue weight of 900 lbs (that's heavy!) then you can load only 500 lbs of cargo in the truck.
