I have a 2012 pro 4x and I am replacing both struts and shocks and I am not quite sure if I ordered the right ones or not. I ordered the Bilstein 5100's to replace the stock ranchos. I am not quite sure if they'll work because I've done some research and it seems that the ranchos have a 4 inch lift? Correct me if I'm wrong. I want to keep the same level look and don't want the ride height to drop. Not sure if I need to cancel and order the ranchos or if the bilsteins will work just fine with the coil overs that are currently on the ranchos. Thanks in advance.
