Does any one know what & ware the 3 wires for the factory phone mic are. i know there in the 32pin harness just need to know what they are, Ground, MIc+ ect. i installed a new kenwood HU, & want to use the stock mic if i can. thanks
The mic wiring goes to the bluetooth module located under the passenger seat. It's not worth the trouble to use the OEM mic with the new HU. Use the mic that came with the HU.
The mic that came with my Pioneer HU had a very long cord. I routed it under the dash, up the insulation strip on the drivers side then overhead to the rearview mirror location. I placed the mic in a small square of foam rubber (shock proofing) and mounted that assembly to the overhead console with double sided tape. Once in place it is not noticable.
1 - 2 of 2 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
