1 - 2 of 2 Posts
My trouble free 2014 Titan Pro4X with 93000 miles has front brake pulsating when stopping. Not in the pedal or felt in the steering wheel, just pulsates and felt physically. I am on my 3rd rotor set and pads. (Not required but trying to eliminate the pulsating) Very noticeable with normal braking, not as bad with a little harder braking. Doesn't pull either left or right. Any ideas as to why I am still feeling the pulsating? I guess the only thing else is calipers. Thanks
Loose Ball Joints
Loose Upper/Lower Control Arm
Worn Wheel Bearings
Warped rotors
Bad tire
Bad alignment
Normally, when the rotors are warped, you feel it in the steering wheel.
My first set of rotors warped around 80K miles. My wheel bearing needed to be replace at around 90K miles.
1 - 2 of 2 Posts
