feel accomplished, I finally got my passenger side and rear 12v outlet to be always on, I had to move the 11p to the 8p location like posted in a previous post. To get the pin removed you have to open the bottom portion of the plug. Just look where it connects and you will see how it slides down. Then you will need to get something small and flat like a very small flat head. Then you insert that where you see a flap push that out of the way and give a little tug and the wire should come out. Here is a picture of the diagram and what numbers they are. I hope this attaches correctly.
