Here is the procedure I used for removing the 2015 Door Panels:
1. Remove the cover from behind the door handle. The first cover gave me a little bit of hassle. You’ll need a small blade flat screwdriver to fit into the slot.
2. Remove the bolt from behind the door handle. 10mm socket.
3. Remove the rubber insert from the cubby in the armrest. This can be a little tricky too, use a strip of thin cardboard or plastic to get under it and lift it enough to remove it.
4. Remove the bolt from the armrest cubby. 10mm socket.
Continued next post...
