1 - 6 of 6 Posts
Hello,
I am a new forum Member. in may I picked up a brand new 2015 Nissan Titan King Cab SV from Gallatin,TN.
Previously i had two Toyota Tundras (2000 RWD and 2002 4WD both 3.4V6). The 2000 one was getting over 230K so decided to replace it with a new truck and after the search and looking at the price of the Toyotas I picked up the Titan. I had 1995 Nissan Hard Body Pick up before i got a Tundra and absolutely loved it, so Titan was an easy choice for me.
I love my Titan. It came with 20" rims. Since in am in northeast I would like to switch snow tires and are looking for 18" rims. Does anyone knows 2015 OEM 18" rim offset? I check Tire rack but they are listing several off setts. I found bunch of the 2016 XD rims (take offs) but can seem to find reliable information on the rim offset.
Would appreciate an advise. I am sure some already looked in to that....
Thank you,
avk
stock 1st gen 18" wheels offset is +25mm ish. 8" wide. (pro4x wheels, not sure if the offset changes on the other trim 18's.)
thank you. Appreciate feed back. Talked to few folks who is selling XD rims takeoff and all say no problem. I had a feeling they were blowing smoke...
the xd rims will probably rub the brake calipers and they'll look terrible. the +50 or whatever offset will suck the tires in a lot.
OEM 18x8 wheel is +25mm offset. So if you go with a 18x9 aftermarket wheel you want a +12mm offset to keep stock. Like honda said, the XD wheels have a much higher offset than we do and you'll run into issues.
Reactions: AVK64
1 - 6 of 6 Posts
