Hello fellow Titan lovers...
I have been trying to find an actual "How To" to have the OEM footwell lights and glove box light added to my truck. People have acknowledged that the higher end models have these lights, and I can see where they go, but just need help actually how to do it? If you can provide me a link or anything to help I would appreciate it.
Truck is a 2015 SV Crew Cab 4x4
Thank You for your time...
Truck On...:rockon
Jeff
Easiest way for the footwell lights is to get some LED strips and wire them in. The cargo light wire is a pale green wire in the passenger footwell. For the glovebox, probable going to need to get a pressure switch then wire it into a wire that is hot when the ignition is on.
So if I wanted to use the OEM bulbs, from the Top model of this truck, it wouldn't work? I was curious if you can buy the bulb and socket and just install them? Or is this something wwaayy more difficult than it seems?
Truck On...:rockon
Jeff
To wire it up OEM-style it's way more difficult than just splicing in some LED strips or bulbs. Fishn's way is the easiest.
