1 - 20 of 24 Posts
· Vendor
Guys just a heads up 2016+ gasser Titan bpipes will be coming very soon. I will post when production starts. :big_grin:
Awesome news Jeff. Pretty close to gen 1 as far as exhaust setup?
I've crawled under the truck and noticed better quality heat shields and pipe welds. The "old" cracked manifold problem seems to be gone, as the new set-up is similar to the Tundra and I've never really heard of any cracked Tundra (2014+) manifolds.
... and by no means am I an expert, just visually pleased from the 1st gen. Subscribed for Jeff's opinion on the improved 2nd gen underbelly.
I'm pretty sure Tundras come with shorties from the factory.
i have the mod itch, no good parts out for gen 2 yet!
Looks similar on new Titan. I took pics but can't upload, as it says files are too big ?!
..if it is still manifolds, they look worlds better than the 1st gen.
At any rate it won't matter either way down the road thanks to Nightowl !
Just FYI - If you make a Photobucket account it's much easier to post pic's on here!
Without Photobucket you have to re-size every pic that you want to post & that's a PITA.
I have one specifically for all my Truck Mods & Misc Truck Pic's.
· Vendor
Discussion Starter · #13 ·
2017 bpipes are exactly the same style in fact passenger side is identlicle other than bung placement and the driver side is the same except 6 inches longer. Tiny pipe 2" is still being used. The XD gasser 2wd and 4wd will be no problem with existing Cajun bpipe line catless, resonated catless or catted. The 1/2 ton gasser will be a ISSUE as there is a cross brace in front of transmission that posses a clearance issue for resonators or cats. Gonna have to get one in the shop for fit testing. Plain catless will be no problem for now.
Great news.
when can you have some catless ones for 2017 1/2 ton :)
· Vendor
Discussion Starter · #15 ·
Great news.
Soon as I get caught up and get the jigs built. Unfortunately in the hospital now with back issue hoping for discharge today....
Ahh man... IDK you were in the Hospital, Jeff.
I hope you are doing good & you are feeling better ASAP!
Reactions: nightowl
Released last night. Herniated disk L3-L4. No surgery for now thank goodness. Thanks guys
you need a nice supportive chair for all that welding you do.
1 - 20 of 24 Posts
