1 - 3 of 3 Posts
I have a 2017 Titan that just started not moving in reverse. I shift into reverse and it just sits there I have to rev the engine before it will kick to reverse. As you can imagine it could be dangerous because it it kicks into gear and tries to take off. Any idea what can cause this?
The dealership can tell you and fix it for free.
Get it to dealership - drive as little as possible even if seems ok in forward gears - hydraulic pressures in tran. sound screwed and could be as simple as low fluid but more likely internal tran. problems
1 - 3 of 3 Posts
