Worse than that in mine.... ughhhh it's terribleAnyone else finding the reception quality is subpar on FM radio
There's an update?FM radio reception sucks balls on my 17 SV! dealer says my radio has the latest update so ...
Well on my new 2017 PR just realized today I don't have AM radio reception. FM works fine, AM doesn't work at all, like the antenna isn't connected? FM seems to work perfect though.so know that the trucks ship from factory with the rods not installed on the fender. then the dealer does the install at pre-delivery.
so if the dealer doesn't torque it down good, or if the truck sits for a while and the screw threads in the nub on the fender are not clean, then reception suffers.
maybe unscrew the rod off the fender, check the screw threads, then re-install. sometimes it's an easy fix.
Good to know. I'm dropping my 2017 PR off on Thursday to get the Transmission "E" update (well at least request it) and to get my non-working AM issue also looked at. I am hoping they are quicker than 4 days.My 2017 SV was in the shop for 4 days because of non-existent AM & FM reception. Per the dealer, they verified that the radio wasn't the problem. Supposedly they had to replace a wire harness as well as the antenna.
All I can say is that both AM and FM work extremely well now.
Supposedly there was a one day delay for the dealer to receive the radio "tester"...which turned into two days. Then once the dealer verified that the radio was good, they had to order an antenna. When that didn't work, supposedly they had to order a wire harness. It's hard to figure what a wire harness had to do with reception, but that was the service advisor's story.Good to know. I'm dropping my 2017 PR off on Thursday to get the Transmission "E" update (well at least request it) and to get my non-working AM issue also looked at. I am hoping they are quicker than 4 days.
Well mine was a "headunit failure" so they will be replacing the whole unit. They said they tested out all the parts and it had nothing to do with the antenna, wires, etc. The guy told me they have a Titan expert who will change it out without marking up the console. We shall see. It sucks as I don't listen to AM very often... however, they I do listen occasionally and having to stream the channel from my phone every time is an unneeded hurdle so I'd rather just get it fixed. I actually never use FM.Supposedly there was a one day delay for the dealer to receive the radio "tester"...which turned into two days. Then once the dealer verified that the radio was good, they had to order an antenna. When that didn't work, supposedly they had to order a wire harness. It's hard to figure what a wire harness had to do with reception, but that was the service advisor's story.
My last four new trucks have had awful fm reception.Anyone else finding the reception quality is subpar on FM radio
