1 - 20 of 35 Posts
that thing looks dope.
Did you do the 2" level on it?
What is the wheel size (i.e. 20x9?) and offset (i.e. 0, -10, etc.)
Are you rubbing at all? Any trimming?
Sorry so many questions looking to level and put bigger wheels/tires on mine too. Just trying to figure out how big I can go on wheels / tires with a 2" level. thanks
Discussion Starter · #10 ·
2" leveling kit. Rims are 20x9. I think the offset is 18. Had to trim a lil on the mud flaps but not much.
Sweet set up!
Here's mine, 2wd SV. RC last gen three inch kit with 1 inch blocks in the rear :devil:
Sweet set up!
So the 1st gen & 2nd gen titan suspension set-up's are the same? So if I got a SV4x4 I can get the 3" kit for it????
Sweet set up!
That's what I'm running, last gen Titan three inch Rough Country kit. Even have bilstiens 5100 middle perched as well from last gen and everything fit perfect for me, the only minor change I made was to the cam bolts I installed to get it aligned, one was too long on the drivers side so I had to cut it down. Rear blocks are last gen as well, long story short yeah everything seems to be the same with only minor changes but didn't affect me when installing everything.
Awesome... I'm thinking about a 2017 SV in March & want to get it lifted right away.
Appreciate the pics BULLEYE.
Since you have the RC 2" level would mind measuring from ground to top of fender in front and back to see if your truly level. I measured my stock '17 Titan from ground to fender and its 36.5" front and 38" back. If I put a 2" level on it it will squat 1/2" inch in rear. Would really be appreciated! thanks
1 - 20 of 35 Posts
