1 - 6 of 6 Posts
Hello everyone,
I need a little help sourcing the Nissan OEM part #'s for the transverse pin and the eccentric washer.
I've done some research but cant seem to figure the part # with 100% certainty.
Can someone confirm if its:
54580-EZ00A Pin
54559-EZ00A Washer
Obviously mine does not have these and the dealer can only look up by Vin #.
I'm installing a Calmini 2.5" level kit with adjustable uca's and I've been told I dont need them but it will be much easier to adjust via the lower arm than having to adjust on the upper control arms.
Thank you in advanced for your help.
Thanks for the response. Those on the part diagram you showed me are for the Titan XD. I already order those and had to return, they are way to Big for the Non-XD model.
I have some stock non adjustable pins left over from when I replaced them on a 2013 Frontier I had, and they sure look the same as what on my 2017 Titan.
I'm trying to source the adjustable OEM version if at all possible.
PRG Products
They don't make adjustable cam bolts anymore since they don't build the trucks with them. The 1st gen ones from PRG, SPC etc should work on your 2nd gen half ton.
1 - 6 of 6 Posts
