1 - 14 of 14 Posts
hey guys! gettin' ready to order some wheels here shortly but i wanted some input on what you guys think? i'm going with the Fuel Hostage Black but on the fence now on the two listed applications. i attached some pictures i found to give you some reference
here's the 20x12 -44mm which gives about 3-5" tire outside the fender:
here's the 20x10 -24mm which gives about an 1-1 1/2" tire outside the fender:
looks like the 20x10 -24mm has more of a flush sidewall bulge vs the 20x12 -44mm which is more stretched?
I hate anything that unnecessarily pushes the wheels out farther than required, just for the sake of sticking out farther.. You're also going to need more of a Pinch Weld Mod with the -44.
Reactions: LSturbointeg
Wider wheel = less tire bulge = look more like a street queen cause if you go anywhere off road those rims are getting scratched.
I agree with the -24, gives a good amount of tire under and outside the truck.
thanks guys for the input! i think i'll stick with the 20x10 -24mm as originally planned!
I would also stick with the -24, I went with -18 an wish it was only say -12 or so.
On a 10" wide wheel 0 is stock offset.
Say guys I wanna add just a 1/2 or an 1" adaptor more to the -24mm. That's still not too bad eh? I've been looking at a lot of 20×12 -44mm setups and tho it's pretty aggressive with the whole bully dog stance I want something in between. I like the 1" outside but it would be perfect for me if I can get 2"! 3-4" is too much for me.
My 20x10 -18 stick out about two inches
Discussion Starter · #11 ·
Vehicle Car Transport Lane Road
Not the best pic but all my pictures got deleted an my phone wouldn't restore over iCloud.
aftermarket wheels need at least a 1.25 adaptor. or else the stock wheel studs will hit the wheel. Stock wheels have a pocket though so the stud doesn't hit if you run a 1" adaptor.
"not the best" :devil:
Discussion Starter · #14 ·
Thanks Honda for the info regarding the spacer! i'll see what it looks like first before anything.
1 - 14 of 14 Posts
