1 - 9 of 9 Posts
Hey guys I’m looking at new wheels but need to know what’s the biggest tire I can run without a lot of running at full turn, if I need to I’ll trim. It’s a lvld 2017 S
Current setup is steel 18’s on 275/70r18
Speaking from experience in lifting and upping my tire size on a 2011, you're likely to be limited on a leveled Titan to either very narrow (like 255-ish) 34" tall tires (if you can even find such a thing) or you can go to something in the 33x12.5 range, which will be 305-315 wide in metric, and the sidewall ratio will depend on the width. You can check at tiresize.com for common and uncommon options.
1 - 9 of 9 Posts
