1 - 6 of 6 Posts
'07 CC
wheels are american racing razor
tires are 305/45/22
will this fit with the +30mm offset, 6.5 b.s.? yes i did a search.
thanks in advance!!
edit::: they are also available in +18mm, 6.0 b.s. Is this better fit?
I think the +30 is for the newer chevys, and they will prob reccomend you go with the +18. If only you could go with +18 in front and +30 in the rear that would be the best setup.
Titan's are classified as mid-offset vehicles. Which means a +15 to a +25 offset. The +18 would by the better fitment. It would be possible to use the +30. FFTitan is right, the +30 is meant for the newer Chevy's. I've asked them in the past on other wheel fitments.
i went with a +20mm
1 - 6 of 6 Posts
