1 - 2 of 2 Posts
Why is it that some 275/70/18s are able to fit on 9" wide wheels while others are not able to fit on the same sized wheels. I dont like this!
according to some people on here the reason why is that most manufactures require a max of 8.5" rims and if you stretched them onto a 9" inch you wouldnt have much of a sidewall buldge... it is possible but its mainly if your at stock height it will more then likly be the offset that will cause rubbing issue at the PWM area...
1 - 2 of 2 Posts
