I am very curious on this as well, as i am looking at new Moto Metal wheels 18x9 and the 295/70/18 terra's and do not want to do the pinch weld mod.I have a 2008 4x4 SE Crew Cab. Im looking at running the 295 70 18 Nitto Terra with the PRG 1.5 leveling kit.
Willl this work? With out having to do the pench weld Mod.
If anyone else is running this and has pics please post them.
What do you think about the 285/75/18 Nitto's whats the chance of rubbing with these on a 18x9 moto wheel with +18mm backspace?In gerenal you can only run 33's without any modification on our Titan's. A leveling kit doesn't matter. The tire you are looking at is 34.5" so you are going to have some degree of modification. You will have to remove or cut the mudflap and depending on how far the new rims stick out you might have to do the PWM. I have read someone on this forum was able to run those tires on stock rims and didn't have to do the PWM.
Te moto has a a +18mm offset, so I'll still need a lift to fit it? Even with a 17x8?only toyo comes in the 285/75/18, but I dont think either tire will fit unless u do the PWM and reshape the fender liner. and with a new wheel like the motos ur gonna need at least a 6" lift to fit those without rubbing
Stock OR rims are 17x7.5 with +30mm offset, which comes out to be 5.4" backspacing.I dont know about the 17x8, but the 18x9 will need a lift for it; if the 17x8 is the same size as the stock OR wheels and has the same bs then it will be a little better to fit underneath but u will still need to cut
