Is this too much gear?? Is there a tuner to fix the loss of cruise control? I bought my truck used - how can I tell what gears are in it now?
Thanks!
Thanks!
so on my 2010 it dont have cruise, can I assume I have the larger gears?What size tires are you running the 20's on is the better question.
You cannot get cruise control if you go above the big tow gears. Its just the trade off of having bigger gears.
Titans come with two stock gear ratios either 2.94 of 3.36 with the big tow package. If you have the big tow package you will have the larger towing mirrors and a transmission oil temp gauge I believe.
the stock tires should be 275/60/20 which are 33", but those gears and truetrac would make that bad boy launch like a mofo
Is this you in these 2 videos?hmm ive always wanted to put 3.73 i have seen setups for them also for 4.10 what u can do to fig. ur gear ratio out in a thoughtful is to jack the *** end up and rotate the drive shaft and count how many times it turns to make the tire turn one time. like example drive shaft turned 3 in 3/4 turn ok close to a 3.73. or just take the rear diff cover off,a nd count ring teeth. and divide by pinion teeth. straight up answer.. hope i helped.. .
08 titan. mods: cai,93 cortex tune, 3inch exhaust ,headers,electric fans ,transgo, trutrax,tbs,bored throttle body,125 shot of nos, smaller tires in rear to lower gear ratio.. 1/4 13.5 101 motor n 12.76 at 109 on spray.. with street tires..
??? WTH ??? Now, I'm really confused... I've read your post a few times & it gets more confusing each time. Do you have input on 3:73s with true trac on stock 20s/tires?Have any proof. Of those times your claiming in the 1/4 mile highly doubt it without drs or slicks...not to mention without a real tune....and to the other question unless it was a complete custom gear swap which you can very easily notice the torque difference ....you either have 2.94s or 3.35s and they don't even compare to 3.73s I have had all of them
yep, that's himIs this you in these 2 videos?
http://www.titantalk.com/forums/tit...t/126971-titan-vs-hemi-found-youtube-new.html
sorry bout the the first question was ment for the other guy that posted saying in his sig that he ran 13.5 on motor.....and the other part was for you...i was saying you would can tell the diff if you haf 3.73s the pull wayyyyy diff then a 2.94 or a 3.35 gear titan.....you didnt really say what you want out of your truck and in our trucks there is a big diff between 3.73s and 4.11 gear...are you looking for a daily driver? or to race? to tow???? WTH ??? Now, I'm really confused... I've read your post a few times & it gets more confusing each time. Do you have input on 3:73s with true trac on stock 20s/tires?
I know this isnt toward me but the OP and I have similar questions. Ill be using mine as a daily driver but want it to race down the track frequently. Not really towing much. Im looking more for performance and dont really care about MPG losses. Recommendations??sorry bout the the first question was ment for the other guy that posted saying in his sig that he ran 13.5 on motor.....and the other part was for you...i was saying you would can tell the diff if you haf 3.73s the pull wayyyyy diff then a 2.94 or a 3.35 gear titan.....you didnt really say what you want out of your truck and in our trucks there is a big diff between 3.73s and 4.11 gear...are you looking for a daily driver? or to race? to tow?
IMO 3.73s are the way to go....you WILL notice a huge difference...some people on here might say otherwise but most all of them have never had 3.73 or 4.11s.....and i have had about every gear ratio made for a titan...good luck with what you decideI know this isnt toward me but the OP and I have similar questions. Ill be using mine as a daily driver but want it to race down the track frequently. Not really towing much. Im looking more for performance and dont really care about MPG losses. Recommendations??
ur motor wont last if u keep spraying on a superchips programmed titan lol plus ur mods are overinflated i doubt u run 12.7 without slips or vidshmm ive always wanted to put 3.73 i have seen setups for them also for 4.10 what u can do to fig. ur gear ratio out in a thoughtful is to jack the *** end up and rotate the drive shaft and count how many times it turns to make the tire turn one time. like example drive shaft turned 3 in 3/4 turn ok close to a 3.73. or just take the rear diff cover off,a nd count ring teeth. and divide by pinion teeth. straight up answer.. hope i helped.. .
You're 4wd....you don't get a choice...no gears for the front diff...Im not trying to thread jack but I was wondering also what gears I should go with. Im running 305/55 R20 and wanted 3.73 or 4.11. Any recommendations on which would give me better performance?
Speed comes off the ABS tone rings on the rear axles, so gear ratio alone won't make a change but of course tire OD does...My 35" tires have me 4 mph faster then indicated at 70 mph....My only concern is how much will the speedo be off?
