1 - 18 of 18 Posts
What's up guys..one simple question..can I add a body lift with my offroad bumper? My thought is no because of where the bottom of the bumper is at on the frame and the way it mounts
Sent from my SM-G928V using Tapatalk
yup! because when you lift the body up 3" that bottom part of your Rhino is going to hit! looks like you're only 1/2" away?
edit: looking at the 2nd picture it looks like maybe? might have to cut on the bottom across unless it might look weird?
those tires are freakin' huge bro!
Reactions: evil-titan
It's a 37x13.5. I've been in the deer woods all week and I would like to get a BL on this thing to feel better about clearance but it won't be able to happen. Oh well.
i'd imagine with any flexing you'll be pretty close to hitting your wheel wells. i can see why you would want a body lift.
haha damn!
You'll need to cut it. Angle grinder will do quick work. Could have a fab guy weld a plate on after the fact to help clean it all up so it's not the frame horns poking out. You'd also need to make brackets for the bumper to raise it 3" with the body lift.
Discussion Starter · #8 ·
So your saying it can be done??? I knew I would have to make a plate for the bumper. What are you saying to cut with the grinder? The bumper ?
Probably could do just the bumper so you don't lose the front crossmember. It can be done for sure. it'll just take patience to make it look good.
3" body lift with road rhino offroad bumper
Exactly what Honda said. Any reputable metal fabrication shop could make easy work of making brackets to raise it up in line with the body lift!
P.S. You need to whore out your truck more lol I love seeing pictures of it
what about the 1.5 prg body lift? less adjustments, cleaner look.
I was thinking that the entire time of reading this, but Honda beat me to it ^. The PRG 1.5" body lift would probably give you more clearance and not need trimming the bumper.
Discussion Starter · #14 ·
I have a feeling trimming the bumper on the bottom side is inevitable. As it sits now I'm only 1/2" away from the frame horn unless I cut more off
I don't think 1.5" BL is enough? You see how close those rear tires were?
Cody S is still trying to sell his PA 3" body lift, Austin. Hit him up.
1 - 18 of 18 Posts
