has any one heard of anybody doing a 3 degree timing advance, my dealership did a 3* advance its badd asss
I think it was adjusted 3* to set it at 17* and get the 2* gain over the stock 15*. I've read there have been a few found that were set lower than 15* from the factory.Carbeaux said:View attachment 54968
But notice the part circled. Wouldn't that indicate that it only adjusted it to two degrees?
This is correct,I think you can initial set to 5 degrees,but ECU will default it back to 2 once Consult is disconnectedbbomar said:I have read, that the most you can advance is 2 degrees. I heard it will default out, if you try for a higher number. Thus, they might have tried for 3, but defaulted back to 2.
BLOWBYU said:You guys running the 2 degree advance I assume are having to run premium is this correct?
