3" leveling kit
1276 8
Has any one used or installed a 3" leveling kit to their 4x4 titan. I am considering installing one of these kits to my truck, and I would like to hear your feedback. Thanks Lock
1 - 9 of 9 Posts
PRGproducts.com, (PRG is an expert on Titan suspensions, and tests his products on his Titans), sells only a 2" level kit for the 4x4, and a 2.5" for the 2wd Titans. With more than this recommendation you will have your stock UCA hitting against the coil bucket. This will occur much more often the higher you go.
You can go 3", that is fine. Only problem is you'll need after market upper control arms.
It'll look like you're driving uphill when you get in the truck. Go for a full lift if you want to go that high. It will look, and ride better.
PRG sells a mini lift which comes with front spacers and rear blocks too lift the rear level with the higher front end.
If your truck is 08 all you will need is just the 1.3" leveling for the front.
yeah nothing i think is funnier than a truck "lifted"
till the front end shoot at the clouds
by the way
i am starting a new site
it is a forum like this one but i am an off-roader (if money will alow)
come take a look linky
1 - 9 of 9 Posts
