as for the shocks you dont have to but if they are stock then i would for sure replace them, if they are not but need replacing then do so as for a block in the rear you wont need it unless you like the rake look then youll neeed it. the lift actually provides 2.5inches of lift not 3 like is stated on the packaging or website....if you can afford it then get some SAWs or Radflo's for the front end from PRG instead alot better if not then its a personal preference if you want to lift it more or not but you pretty much about maxed out from my understanding unless you get aftermarket coil overs for it and willing to do some grinding of the coil bucket....personally after purchasing it and having installed on my truck for a few months now i wish i would have listened to otehrs and got the prg UCA instaed.... the ball joint on these from what i understand need to be changed out to be very reliable and well thats like 35$. still cheaper..for sure get the new rear shackles no matter what thats my next order from greg at PRG.... you dont want them going through your bed it sucks and scary im sure when it happens...... good luck and sorry so sparatic early in the morning answer lol
